s-techs
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
nismodan69
Car: 2007 g35 coupe 5AT sport
hi guys i was searching thru the forum for all the info on springs and it seems that camber is a very big issue. i was thinking of getting the s-techs from the 350z because i read that the back springs are harder? am i correct on this? and what year 350z springs do i need to get? can i manage to get factory spec back after the drop with a good alignment? i dont think i will have enough money to buy the camber kits if i cant so i need to know if its possible to not waste more tiree!!! i have a coupe by the way
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Whatever the s tech drops the z, add another .5" for the drop on the coupe. I think you should be fine as far as alignment goes. If you can keep the camber @ -1.5 or less is the key.
nismodan69
okay cool thanks alot. and what is the basis for adding .5" to the amount the springs drop the z? is it really true? because if not.. i dont really want to buy springs that only drop the car about.7 of an inch front and .55 rear
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
the stock Z is .5" lower than the coupe, 1" lower than the sedan
so, if you put on Z spec springs, you will end up lowering it (on a coupe) that 1.2 / 1.05
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
