You'll need to get some heavy duty valve springs and some can be found at Jim Wolf Technology for a little over $200. To be on the safe side have your valve reliefs on your pistons enlarged (good insurance). As float suggests, a set of adjustable cam gears will be a useful tool as well. With all that being said, follow these tips andyour new head and goodies should net you some good power and performance, granted the car is tuned correctly.tnslide80 wrote:im gunna be buying tomei cams with these specs 270 duration?‹ 8.80 mm lift.would you suggest running anything other than springs and retainers.....and is there any other place where i can get good quality springs cheaper than tomei???my head is getting ported and polishednow so i need to figure this stuff out fairly quickso i can get it on order..thanks
If you can aquire Tomei cams, go for it. Jun makes good cams if you can find some as well as HKS. With some mild porting and a good valve job, you should gain some useable horsepower. Just make sure you arm the head with some good valve springs and control the engine with some sort of functioning engine management device that can be tuned by someone and you should be happy with your investment.tnslide80 wrote:would you suggest any other cams or go with tomei???they are about the only ones ive found....but i do trust that name so.......but you are far more knowledgeable than I when it comes to the ca....so any tips will be appreciated...thanks
Your turbocharger choice, engine management, tuning, and the accomodating facts determine where your set-up takes.dattodude wrote: Seriously though. I'm yet to see any decent value in my 270/9.25/solid lifter combination.
I could've gotten my kitchen remodeled on what I paid for the work done on my head including the JUN components, so I know exactly what you're talking about.dattodude wrote:I could have bought 2x S15 SR20det for the amount I've spent on my head alone.
