I personally do not want blowby being routed back into my intake. It lowers the effective octane of a fuel. And on top of that, an electric vacuum pump will pull GOOD vacuum on the crankcase instead of the minuscule amount that the compressor inlet will pull.rlvq35de wrote:This topic always comes up. No one comes up with the ideal setup.
I believe without going nuts on the pcv system, the best way is to put a filter on valvecover, plug the ports on the bottom of your intake. Route a line from PCV valve to catch can, and then catch can to intake pipe, pre turbo.
Thats how im doing it. I definately think boosting the stock system is very very bad, Those PCV valves will not hold high boost pressures. And piston ring failure is definite.
Rob
Well, mine's all custom fabbed (coldpipe), but yes. Just plug it.1995240sxSE wrote:but did u plug off your intake ports that the crankcase vents into?
Look on 240sxTech.com, article is titled "timing your KA" or something like that.1995240sxSE wrote:while I got these guru's are gathered, not to insult y'alls intellignece, but what do the marks on the crank pulley stand for. I have been searching and cant find a damn thing! i know it like xx, xx, 15 and 20 btdc,. I searched the fsm nothing. which one is 20 and what and where is 15 and so on and so forth
as i stated, withoug going as crazy as putting an electric pump, i think that is the easiest most effective way. I honestly do not believe i will get that much loss in octane, and will pull plenty of vacuum to ventilate crankcase effectively. Alot of people outside the KA world run a similiar setup and have ZERO problems.nissanfanatic wrote:
