s currentlyVG33E Timing Marks
240sxinlv
Hello,
Got a 2002 Frontier with VG33E. I was checking the timing cause I was getting a little pinging. There are 5 marks all look white. It is currently on the center mark. Hood sticker calls for 10btdc. Is the center mark 10btdc?
Thanks
Modified by 240sxinlv at 9:50 AM 10/3/2006
Modified by 240sxinlv at 9:51 AM 10/3/2006
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
This is the information you seek. It's probably the Knock Sensor causing you the trouble. But it will act up if you have low octane fuel in your tank.
The Knock sensor detects pinging and it will adjust the air/fuel ratio to compensate for the problem which will rob you of power.
Try a tank of premium fuel, change your fuel filter ( At the tank ) and pour a small 4-6oz bottle of Fuel Injector Safe Methyl Hydrate (gasline antifreeze), in your tank. This will get rid of possible moisture in the fuel system that can contribute to the problem.
And as for the timing marks...select the link for the image.
