Read the first postr34 gtr wrote:what all is done to this motor?
I know when I tried -4 or -5 for the low, mine would start idling like crap.......+4 makes it idle slightly better than 0.r34 gtr wrote:+/-? ive got -6% low and +2% hi for mine (with 510s and the gt28) and it runs like a$s. dont use my settings
Bumpty bump........RS12Turbo wrote:out of curiousty, how did you come up with your numbers?
You car must run INSANELY rich. Your lo-throttle point settings should be somewhere around -25% (injectors are 28% larger). hi-throttle needs some widebandage tuning to get the numbers even remotely close. Death to all SAFC's!!!!!!r34 gtr wrote:ok, i went and checked my settings because one again, i got into it and it knocked. whee. it was only 194 this time so not quite as bad as before, but still gay. anyway, my correction points are the preset ones: 800, 1400, 2200, 2800, 3400, 4000, 4600, 5200, 5800, 6400, 7000, and 7600. for LO i have: +2, -2, -4, -3, -2, 0, +2, +3, +4, +5, +6. for HI: -1, -3, -5, -3, -1, +3, +4, +5, +6, +7, +9, +10. it knocked at ~6800rpm with 65% throttle, so im gonna go back and fix it. i know the maps cross up a bit, but it seems to work for me. this is fmic, gt28r @ 10psi (? damn autometer), 510cc injectors, intake, catback w/ stock dp and cat (which has no material left, hence flames), etc. etc.
I've just started screwing around with mine, so it's a learnig game for me, since I don't have a wide band, and the instruction manual is pretty vague.......and I did hit fuel cut the other day @ 13psi with + low and high settings.That's why I asked what basline settings I should start with.......so again if anyone knows some good baseline numbers please let me know.I have stock injectors, stock maf, t25g, walbro 255c-rad wrote:Why are ANY of you in the + side? All that will do is get you closer to hitting fuel cut.
it doesn't work exactly that way. remember, you're using airflow correction, not actual fuel correction. you'd be on the ball if it were that easy. the AFC is modifying the MAF sensor reading, telling the car there's more or less air coming into the engine.c-rad wrote:
