RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Fri Feb 09, 2007 6:03 am
Don't know how normal or abnormal this is.........Ever since I did my swap, my s-afc2 will detect knock. The weird thing is it will display 0 for like a hr of constant hwy cruising, then all of a sudden it will start teetering between 0 and 1, then after a while will stay on 1.....it will keep doing this up till about 5. Other times it will stay on 0 while cruising, but then when I come to a stop and idle down, it will go to 1 or 2, then when I get back above 8% or 9% throttle, it will go to 0 again.Both scenarios start only after about a hour of driving. If I shut off the engine for 5-10 mins while getting gas or something, when I crank it back up, it reads 0 again for about another hour, then it starts again.Is this a common normal problem with the s-afc2, or do I possibly have an issue somewhere? If an issue, where should I start looking?Thanks for any info
