In
98240 wrote:I wouldnt cut the wires i were you I would use these. Not cutting is required all youdo is put the wire inbetween the piece of metal and clamp it down. You can get them at a hardware store, Fry's electronics, Or autozone. Those are the places I have seen them. I think they are called tap connectors.
http://www.minute-man.com/acat...0.jpg
or solder the wires in.
Unfortunately you can not just splice...you have to cut the MAF wire. When you splice you are simply "tapping" into the wire with no intention to modify the voltage from point A to point B. Tapping into the MAF wire with those connectors will bypass the SAFC altogether and the voltage signal will go "untouched" by the SAFC. You will not have the ability to adjust the fuel percentage. It's really very simple. As others have already pointed out...
Once you cut the MAF wire in half approx. 8'' from ECU harness to give you room for error (Pin 47)...- The wire coming from the MAF is to be connected to the white wire on the SAFC. - The wire coming from the ECU must be connected to the yellow wire on the SAFC.
BTW, the correct harness diagram for U.S. spec vehicles can be found of the Apexi website. The PDF is named "S-AFC Vehicle Specific Wiring Diagrams". The problem is, the diagram doesn't outline all the pins needed for the install. It is the correct harness. You can tell just by looking at the shape and arrangement of the pin outs.
http://www.apexi-usa.com/support_wiring.asp
Per Apexi, the correct harness is named "N-1". Just use the link provided from Biggamehit.
http://www.plxdevices.com/ECUD...9.pdf
The highlighted diagram from Ligouri Rd has the RPM Pin incorrectly labeled. Simple typo, although both of their documents provide the same info.
Pin 1 - RPM INCORRECT RPM should be Pin 3 (tap into wire)
Pin 23 - Throttle Position Sensor (tap into wire)Pin 26 - Speed Sensor (tap into wire)
Pin 39 - Ground (Two grounds, brown wire closer to ECU, black further down. A two finger distance between is all that's needed. Apexi advises to use Pin 19 for the ground. It's probably to reduce wire clutter on one side so it shouldn't matter)
Pin 47 - MAF (cut wire)Pin 54 - Knock Sensor (tap into wire)
Pin 56 - Power (Apexi advises to use Pin 38 for the power. It's probably to reduce wire clutter on one side so it shouldn't matter)
Hard wiring and heat shrink is the way to go. If this car is your baby don't half *** anything you can do yourself. You might as well practice and attempt to show "professional work" to impress yourself if not others. Soldering is a skill that is often overlooked but silently respected if done well. Playing with R/C cars since childhood makes you a pro.
Just follow the pin outs indicated and you'll be fine. This is exactly how my SAFC is hooked up and it works like a charm. Don't hesitate if you have any other questions.
