Bang!
http://www.apexi-usa.com/produ...e.pdf
This is for the blue display gen 2 SAFC but the pinouts are the right ones for the KA, use this manual to indicate which wires are specfic to th gen 1 SAFChttp://
www.apexi-usa.com/produ...1.pdfthe dip switches appear to be the same for most Nissans, from the left; up,up,down,down,down,up,down,up
now the car select dial gets sketchy, this is not a setting shared on the SAFC gen 2 so you will have to screw with it. I am not sure if you have an S13 or S14 so let me throw out everything on this for all models.
the gen 2 manual A-spec lists the followingS13 KA24E/DE Comp type N3-b sensor type HW5S14 KA24DE Comp type N1 sensor type HW5
I looked for a J-spec car that matched these for the gen 1, no dice.These are some that are close;S13 SR20DET Comp type N3-B sensor type HW6 S14 SR20DET Comp type N3-A sensor type HW5
If it were me I would dial in the S14 setting because the AFM is right and the computer is close, this would be "5"
I would get an Air/Fuel meter before I messed with this unit though, hooking up and tweaking the SAFC on a car it was not intended for without a way to monitor it's effects is dangerouse.
