rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Mon Apr 05, 2004 1:02 pm
NO, jwt does not run it rich so that u can go buy a s-afc to fine tune it.They run it rich so that your motor stays on the safe side.
However, running rich for long periods of time is bad on the pistons. Also running lean is bad on the motor. Thats why the air/fuel mixture has to be fine tuned. For short time, running rich is good, but in the long run it will do some damage. Thats why people buy the afc and FINE tune the air/fuel mixture so that the motor runs properly, they pick up more power, and the motor lasts longer. U really dont need the afc to fine tune it. If u get the jwt ecu, throw the car on the dyno and see what your a/f mixture is like. If its too rich, then buy the afc and fine tune it. If the a/f mixture is fine across the board, then u dont need the afc. More than likely you will need that afc..!!
To run 10 psi, you will need an upgrade to your fuel system. That means, larger injectors, larger fuel pump, larger fuel filter.Then as far as the actual fuel management, u have several options:JWT ECU with or without AFC depending on a/f mixture after dyno run.Greddy EmanageStand alone system- SDS- Howtech etcS-AFC ALONE, but then u will have to retard the base timing to compensate when boost kicks in.
There are several options out there. Its just a matter of preference and how much power your goal is and how much money ur willing to spend
