s13/altima wrote:
I think you have them reversed. the first link shows the OBDII ecu. and the second link, that should show the OBDI setup, isnt working for me. and the instruction book, I got, doesnt give any specific detail about ANY KA24DE setup. So, Im not sure which wires to splice into
Sorry about that, you are right, I do have the links backwards.
But anyway, it should be diagram (N-3b). If you look on that link (the 4 page one), look at Nissan in the chart. It shows the S13 with the KA24E and KA24DE both as diagram N-3b. Because the Altima uses the same engine, the ECU pinout *SHOULD* be the same. The S14 with the KA24DE is listed as diagram N-1 (from the USA suplement), just as the U13 with the KA24DE is.
Make sure you have the correct wires off of the SAFC connected. I think there are two grounds (brown and black?) and they must be connected in a certain order. Also, make sure your MAF signal is hooked up correctly. Is the SAFC even coming on? If not, then your power wire is not hooked up correctly. Find out which SAFC readings are messed up, then double check the diagram.
