iknowyoulike wrote:
Use the one that i posted up, that's the right one...if you check apexi site it'll list to use this pinout guide for the KA. I know that it's not listed on the s-afc part of the section. You gotta look at the AVCR installation guide and it'll show you that you gotta use the n3-b diagram. that's how i knew it was right.
For my car, I had to use a different diagram. My car, a 95 automatic 240 used the diagram 5n-b which had all the wires exactly where they bshould be. The only exeption was the throttle signal, which I found to be the fourth wire on the top row of the 1st 4 cluster ( Ihave the factory manual, which tells me what all my wires are).
