fo0manchu »
https://forums.nicoclub.com/fo0manchu-u4272.html
Sun Nov 01, 2009 12:49 pm
adjust decel air settings:
go to monitor and monitor for rpm, air flow, and throttle.
If you have your ne1 set to 1000rpm, then rev to 1000rpm, see what the air flow is and set it to that.If you have ne2 set to 2000rpm, then rev to 2000 and set the air flow at that value and set the throttle % you see for the decel air throttle%
If your ne1 is set higher like 1500 then rev it to that amount.
Works for me. Hope this helps and makes sense. I still have problems with the open air bov though. I just might end up recirculating it.
