Hey everyone, I am currently running an 11:1 compression KA24DE tuned by JWT. Yeah it's quick. I had plans to upgrade my colt stage 2 cams to something bigger, but am now thinking of another path to walk my all motor KA down..
I currently have a 2nd generation Apexi S-AFC on the way, and also will soon have a Z32 mass airflow sensor in my hands. I'm hoping to open up the engine a little more with the bigger mafs and then fine tune it with the S-AFC. I am being told by lots of people that JWT downtunes their ECUs to run conservatively on different setups. For instance my ECU isn't even tuned for my colt cams. i'm also being told that I have the ability to make some great horsepower by simply tuning jim wolf's setup with the S-AFC. The Z32 mafs was my idea hinted at by Asad from Freshalloy. Why not upgrade if the AFC has the ability to program for it you know? Can only gain horsepower.
Also when I do end up going to bigger cams, perhaps I'll be able to tune them with the s-afc instead of sending the ECU back to JWT for retuning!
Okay I guess my question is, does anyone have any experience tuning with an s-afc and a Z32 mafs on an NA setup? I've never done this before but I understand how it all works.. I guess what will happen is the Z32 mafs with read more air because of the bigger size, thereby adding more fuel.. Do I want to the lean that out with the s-afc or continue richening the mixture? I was told that you want to lean it out just to the edge of where you start to get knock. Is this true? How careful will I need to be with this considering I am running a fairly high compression inside the cylinders?
Any help will be appreciated! I think this is good conversation cause I don't believe I've ever heard of anyone doing this on an NA motor, let alone with a high compression engine already tuned by JWT...
I can't wait to see how it turns out. Hoping for over 200 to the wheels afterwards. Gonna get some dyno time.
'95 S14http://
www.projectaspec.com
