it only screeches on tight turns. my friends welded diff never rattled.. dont know what your talking about there.WDRacing wrote:I wouldn't do it to a daily driver. A friend did it to his 180 in Japan and his car screeched and rattled on any turn with more then a slight degree. Grab an LSD from the junkyard. WHat type of driving are you looking to do? Drag?
WD
I'm gonna go with Chez on this one. The differential (LSD or open) is designed to allow the inside wheel to spin more slowly than the outside wheel, keeping the car from being pushed toward the outside of the turn.solaris22 wrote:You're saying an open diff can take a corner faster than an welded diff?
he was kiddingDustin240 wrote:3 sec< Sorry I call BS on that one. Are you runing crazzzy horse power or you just dont know how to launch.
2 ways arent good for handling either, neither are open or viscoussolaris22 wrote:So with that logic a 2way LSD would also corner worse then a VLSD or an open diff. The welded acts very similar to a 2way in cornering, the difference being a 2way provides less lock when decelerating.
I'm not going to type out a long reply, do whatever you want. I stated earler theres no replacement for a quality clutch type unit. I've owned a 1.5way, 2way and welded. They all have their pros and cons.
Here's mine, I pointed out the spots that are welded. It needs to be very clean. Also, it's best to use a high nickel rod when welding.Florida240sx wrote:Anyone got pics of their welded diff?? My shop won't do it unless I give them a pic...... Any prepping needed??? Spray carb cleaner on it and dry??
