?'s about sr20det...
SlideSociety
hey fellas...i have searched for days and i cant find much of anything on the questions i have about the sr20det.
How much wheel HP is the stock SR bottom end good for?
at what HP rating would i need(recommend) changing fuel system(injectors, pump...ect....i know this is an opinion and many people have their own...but everyone jump in and let me know)
also, if i were to have an engine imported myself, what do you recommend? red top, black top, notch top? and who would you recommend me having import it instead of going to a performance shop and having them install one of theirs.
also...at what RPM does the SR stop making power?
and an off topic question...what is a good helmet for autoX and drifting in events?
Thanks in advanced for your help. and yes i did you the search and i couldnt find exactly what i was looking for. THanks!!
Modified by wishin4car at 9:42 PM 5/3/2005
Nismo_Freak
Car: 89 Nissan 240SX
If you are looking for a stock-internalled high power motor then get a S13 Blacktop engine. They have the stronger 54C internals.
I personally think the SR shouldn't be taken over about 400 if you are looking for long term reliability. I'm not saying it can't be done... I'm just giving you my personal opinion.
370cc - 270whp550cc - 400whp740cc - 520whp
Give or take on the injector limits... depends on BSFC.
SlideSociety
thanks for your help dood. what is the difference between a s13 blacktop and a notched blacktop with the internals? thanks for the help again
anyone else...jump on in.
180fan
Car: 89 fastback
Heads are different (use of VTC on the s14/15 heads), the s13 blacktop has ribs on the front instead of being flat like the redtop head, front cover from s13 sr to s14/15, and water pump are different as well from s13 to s14/15. Oil pickup is different in the redtop to all the blacktops.
SpeedRacer1
Car: 1990 240SX, G35
The bottom ends are generally the same.
S13+S14+S15 blacktops use the same:connecting rods, crankshaft.
S13+S14 blacktops use the same:Pistons
S14 K's MF-T Autech + S15 blacktops use the same:Pistons
This is from the factory, if you needed aftermarket or new OEM parts, they all use the same internals.
SlideSociety
very very cool...thanks for the help fellas...its much appreciated....how about the power issue? when do these engines stop producing power? (i know in my old supra it was at about 5700 rpm)
Thanks again guys
Nismo_Freak
180fan wrote:Heads are different (use of VTC on the s14/15 heads), the s13 blacktop has ribs on the front instead of being flat like the redtop head, front cover from s13 sr to s14/15, and water pump are different as well from s13 to s14/15. Oil pickup is different in the redtop to all the blacktops.
93 Model Redtops have ribbed front covers.
Nismo_Freak
wishin4car wrote:very very cool...thanks for the help fellas...its much appreciated....how about the power issue? when do these engines stop producing power? (i know in my old supra it was at about 5700 rpm)
Thanks again guys
About 7000 or so when you run 14 PSI on the stock turbo. The HP is there but you can feel (and see) the turbo running out of steam.
SR 240Z
Enjuku Racing in Florida i believe, is running 544whp on stock bottom end on an s13 redtop. hell of a beast there.
