bulld0g wrote:I have the Tanabe's and no issues at all I drive about 190 miles a day on them......hanlding is better than stock...the only issue you may have is steep driveways if your not used to driving a lowered vehicle
about $0 installed them myself.....1.5" dropAdiaz360 wrote:cool man thanks...also, after buying the lowering springs (tanabe) how much (if you dont mind me asking) did you spend on getting them installed? and how far a drop is that?
Springs installed + alignment + tire balance should be less than $300 (at least mine was about $280).Adiaz360 wrote:cool man thanks...also, after buying the lowering springs (tanabe) how much (if you dont mind me asking) did you spend on getting them installed? and how far a drop is that?
Don't take this the wrong way - but I really recommend against you trying to lowering your vehicle yourself.Vahagn23 wrote:2 questions, how fast will shocks and other parts wear out with lowerd springs compared to stock springs. second can I install them by using that jack to lift the car up or does it all have to be up of one of those things in the shop?
I have over 15K miles on mine already no problems so far....I just posted a DIY for the lowering springsVahagn23 wrote:2 questions, how fast will shocks and other parts wear out with lowerd springs compared to stock springs. second can I install them by using that jack to lift the car up or does it all have to be up of one of those things in the shop?
Not all mechanics are the same. Based on Vahagn23 's past posts - I hope he'll get some help from another DIY mechanic to learn the process or have a shop do it on his behalf.bulld0g wrote: Why?
For example - when he's asking about the "jack," I believe he's referring to the jackscrews that come with the Versa.
