You will need the S13/S14 Bell housing if you use a 240SX transmission (might as well get an SR 5 speed transmission). Also like stated by SpeedRacer, you will need to match the clutch and flywheel with the transmission that's on it, not the motor.GT Ranma wrote:Yeah, I knoticed ; ;
Would the transmission in the S-14 240SX mount up on the S-15's SR engine? That will save alot of time and trouble that way ^^ We can do a little modifications, but not to much :p My welder is half blind now >.< And he doesn't want to get glasses *sigh*
They have the Spec R which is the Sr20de"T". That came with the 6spd transmission.GT Ranma wrote:Hiyas ^^ But does anyone know about the gear ratio for this transmition? I am getting an S-15 Silvia clip with the 6speed transmission and (this might seem petty) am wondering exactly what ratio defrential I should buy to go along with it ^^;; We also got an Audi S4, it has a 6 speed, but the gears are so close together you have to shift SOO often it's annoying. So I'm wondering if the 6-speed in the S-15 is like this, then I might go a higher ratio then normal, if not keep it about stock.
Is the 6-speed even stock in the S-15's O_o; I never had one, and my friends over there didn't either, so it was news to me when I saw one for sale with one ^_^;; Oh well, can't know everything.
Naw, I had a 1995 which was the newest of anyone I knew. Everyone else had S-13's because they didn't want to buy an expensive car then mod it.aznromeox wrote:They have the Spec R which is the Sr20de"T". That came with the 6spd transmission.
Then they had the other one which wa a sr20de. Non turbo 5spd.
The s15 transmission is close ratio. So meaning. its exactly like your s4. Some guys choose to put 5spd trannys to replace the s15 because of the constant shifting, also the spd is weaker. BTW its a tad big bigger as well.
And driveshaft. And half shafts if you use the diff.VitaminT wrote:So with this said can I use the 6spd on my redtop if I have clutch, flywheel, transmission, diff?
Woo, do you have the driveshaft for it too? ^^ I am interested, but I don't know how long till I can get the engine. . . We didn't make as much money as we thought we would, so a little low on cash. Going to wait a few months to buy the engine now, we have the 3.5K to get the engine, just not enough to buy all the other things we want to do with it ^^; And if something happens, we have no money to replace or buy what we need. Soo, how long are you going to keep them for?racer52 wrote:I have a s-15 rearend i'm looking to get rid of. it has the diff axuls and control arms. and the brack discs. let me know if you might be intrested
