s-13 5speed swap, dash harness?
soberjoeS13
Car: 91 240sx
i have an auto ka24de 92 fastback, im swapping my 5 speed into it. do i need to use the dash harness and manual ecu from my old 5 speed?i read the right up and i didn't see anything about swaping ecu's or the dash harness or any harness (besides the 5speed trany harness.
so do i need to re wire behind the dash? and pu the 5 speed ecu in?
driftapimp
Car: 89 240sx coupe
no u only use lower transmission harnessleave auto ecu it worksunplug auto transmission ecu thing in pass upper kickif not no biggietheres no wiring nothin jus plug and playgood luck
soberjoeS13
Car: 91 240sx
isn't there any wiring plugs to plug into the clutch pedal? like a shift lock? because in the rite up it says to un-plug the green box then plug it back in?? but that box is mounted to where the clutch is going in about 4 hours..
