cnichols »
https://forums.nicoclub.com/cnichols-u493.html
Fri Sep 19, 2008 9:43 am
Less bad grammar and more patience...I'm sure we'll get you the info you need. I really doubt you needed the answer in 30 minutes unless you have a lot of money burning a hole in your wallet.
I would have to say that the LS1 could be done cheaper IF you find a good deal on an iron block 5.3 and go that route. Otherwise, there is no clear cut answer. There are too many variables, such as what kind of deals you can find, do you plan on leaving it stock, what kind of transmission do you want, etc. , etc.
No, I do not know where to find a 2JZ kit for the FC (I'm assuming that's what you're asking). There are a couple made for the LSx series into FCs, but have not seen a kit for the 2J. I seriously doubt it will be very hard to do youself as it supposed to be almost a direct bolt-in for the Nissan S chassis.
