Just curious but can anyone confirm this? The wheels are a bit wider (16x8) so I thought that would throw it off a bit. I tried to fit my FD wheels and they didn't clear on the front. Now I'm trying to figure what size spacer I'll need. Thanks!R240NA wrote:
Nope, all Toyota passenger car wheels have a smaller hub bore. I checked it, it's 61mm. Unless you bore out the wheel it won't work. A 50mm whell would need a 10mm spacer to match the OE offset, lower to clear brakes/coilovers/etc.
Thanks, just curious because with the calculator I'm using it say I lose 29mm of inner clearance. I'm not sure how much clearance there is on stock suspension (as I'm on coilovers right now) and have a set of RX7 wheels laying around that only need one tire for a complete set of basically new tires. I'm going to a shock/strut/spring combo and am not familiar with the dimension of stock S14 suspension.hannibal wrote:R240NA (Rusty??) knows his stuff. I cant confirm what he said, but I'll take his word for it.
