I enjoy the rotary hate. My GT-R is broken and I am driving to work and picking up parts to fix it in my three years older RX7. Oh the irony.
Rebuilding a rotary is fairly straightforward. It's just so different from a piston engine it can seem difficult. This is all there really is.
[youtube]
http://www.youtube.com/watch?v=ijJeUk_GqiI[/youtube]
There are tricks and techniques to learn, but you need to do that for putting together a slug motor too. Most people are inside the box lazy f***, though, and can't or don't want to understand the basics and just badmouth the design to cover it. They peddle that off as a legitimate opinion to people who don't know better which is unfortunate.
I really like rotaries, but I'll tell you straight up, at the risk of drawing unfortunate parallels, rotaries are "lifestyle" engines. Gay jokes aside, owning one forces a fundamental shift in your thinking and adjustments to the way you live. Slug engines are boringly commonplace and considered "normal." You can be anybody with one of those.
If you own a car with the spinny triangles you can expect your engine and you as a person to be treated with disrespect and ridicule as you have already seen above. Your knowledge base will be smaller and populated with a greater percentage of strange folks. Something is a little different in the heads of rotary lovers, sometimes it's a lot different. Being automotive outcasts, rotary folks tend to stick together a bit more, but there are the alpha ***holes in that camp as well.
You will often be on your own when trouble arises and it will. It's a machine and machines fail. Despite what the slug runners would have you believe, their beloved engines blow up too. Break it to them easy, though; they are really defensive and pathetic about it. "They blow apex seals!" Yes, they do. It looks like this.
It usually damages the rotors and housings. Guess what causes that? Detonation. Luckily piston engines can run just fine with detonation. Wait, no they don't. They blow their "apex seals" too. It looks like this.
It will usually damage the block and sometimes the cylinder head, BUT there may be some meat in the cylinders that will allow you to overbore the damage away, a definite good thing. Rotary housings have much less meat to play with.
"They are too thirsty!" This depends on you. Rotaries are not so efficient with their use of fuel. They drink like Irishmen no two ways about it. This will either be a deal breaker for you or it won't, but it will certainly impact your life to a degree. If it's too much, it's just too much. Be honest with yourself and you won't be sad either way.
"They are unreliable!" You know, let me tell you a little story about turbos. In the 80's Nissan had several turbo cars in the lineup and so did other manufacturers. Older more in the know guys, GREG, weigh in on this. The prevailing "wisdom" was turbo cars were unreliable. They were, but why? People weren't taking care of them and they were locking up and blowing up. It wasn't the turbos' fault, it was the users'. Ever wonder why the 240 came with a KA24 and not a CA18 or SR20? Nissan probably thought it wouldn't sell in the states with a turbo engine after a decade of Americans bitching about the unreliability of machinery they were abusing. Same thing with the rotary.
Typical piston engine conventional "wisdom" will kill a rotary. These things operate more like a two stroke motor than a piston engine. They burn oil and gas and have no valvetrain. Porting lubrication techniques are very similar. It stands to reason that my love of rotaries and 2 stroke bikes are very similarly motivated, simplicity and peaky power. 2 smokes are also lifestyle motors. You either like it or you don't. You can either keep it running or you can't. Some can, some can't. If you are one, but trying to live like you are the other you will be unhappy.
I don't get the swaps. I think the rotary folks get their panties bunched up a bit too much when somebody pulls a rotary in favor of a slug motor, but try sticking a 13B into a 240 and watch those guys whine like bishez. It's their cars, they should express themselves any way they see fit and so should you.
I hope you don't have any major drama with it, but realize you likely will. It's like going out with a crazy chick. Sure, the sex can be great, but she might stab you in your sleep.
