RWD or AWD? How do you know?
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
laro1965
Is there any way to know if an FX 35 is AWD or RWD? I bought my 2007 used and I thought it was RWD. However, when the insurance company entered the VIN it came up as AWD. Also, I've seen the AWD warning light in the dash when I start the car. That may not mean anything though.
Are there any controls only for the AWD? Thanks.
1M2NV
Car: 2006 Infiniti M35x Fully Loaded
vin number will definitely determine if it's rwd or awd.
Socaldiablo
Car: 2004 Infiniti QX56 - Black on Willow
2016 GMC Yukon XL Denali - Black on Black
2006 Ducati ST3
2008 Kawasaki KLX450r
You may or may not have a button for this. I have the FX45, which is AWD, and I have no button to place it in AWD. I believe the AWD on these FXs only activates initially upon accelerating when the car was stopped (and it remains in AWD for a brief moment, then shifts power to the rear diff after a few seconds) and when the vehicle senses tires are slipping. One good way to know for sure is to get underneath the car and look to see if there is a front differential and a rear differential. If you have both, you have AWD. If you only see a rear differential, then you don't have AWD. I can't remember now but the plastic skid plate may block your view of the front diff. You may need to remove this to verify.
Tony Two-Tone
Car: 2003 Infiniti M45
Look for a transfer case on the rear of the transmission and a driveshaft going to the front. There wouldn't be any controls for it as AWD reacts without driver control.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
This question can't be real. :rotflmao
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
