rwd ca18det throwout bearing and pilot bushing?
fitch9014
Car: rocket powered, monkey navigated, salt flat special
which one of these pieces of dirt do i use? pulsar, 200sx, 240sx, maxima, 300zx, q30? it's a veritable nissan smorgasbord when it comes to this engine set and i feel compelled to ask...it's like why does the earth circle the sun and why, like bwana, i feel chad kroeger sucks sweaty monkey balls...new tour bus full of old guitars my ***...
mbmbmb23
http://www.importpartspro.com/ni30robepibu.html for the pilot bearing......
Z32 throw out bearing.
float_6969
88 Pulsar SE pilot bearing (althought I think all Nissan pilot bearings are the same) and an S13 TO bearing.
Two-Fortee
Car: 180sx.
Throw out bearing I believe you can use one from a 240sx...Im in the market aswell...
mbmbmb23
All the nissan pilot bushing bearings are the same, the best pilot bearing option is the one I posted above if you are willing to spend a few bucks more.
The KA throw out bearing will work, but so will the Z32 and its bigger and more stout.
Anyways...
fitch9014
if you use the bigger z32 throwout bearing, do you need to upgrade to the nismo slave cylinder?
mbmbmb23
fitch9014 wrote:if you use the bigger z32 throwout bearing, do you need to upgrade to the nismo slave cylinder?
No, these parts don't directly affect each other. The only time you would possibly use the Nismo slave cylinder is if you bypassed the clutch dampener box and replaced all rubber lines with braided stainless.
-m
biosehnsucht
I replaced the lines and bypass the damper, don't need the nismo slave cylinder
That's for when you have an upgraded clutch plate that requires more force to move (due to greater force applied to the clutch), I believe.
