nismoplsr »
https://forums.nicoclub.com/nismoplsr-u10684.html
Wed Apr 11, 2007 5:43 am
Ive never heard of anyone anywhere using the AWD transmission. So its going to be hard getting any straight up answers. Do you have an AWD engine set in hand? If you do or when you do just take some measurements...
Diameter of clutch discdiameter of input shaft of transmission# of splines on input shaft# of bolts for pressure plateheight of throw out bearing
Once you get that we should be able to figure out which clutch set will work for you.
