Seishuku »
https://forums.nicoclub.com/seishuku-u28745.html
Thu Jul 15, 2010 8:43 pm
Well, the problem area is going to be the pistons, they're just not designed for boost. However, if you plan on rebuilding it, you might as well just get some DET 8.5:1 CR pistons and just run it like a DET.
Otherwise, 7-10PSI on the stock 9.5:1 pistons wouldn't normally be an issue with a T28, but more than that and you risk getting hot spots on the pistons and might seize a ring.
But keep the NA cams, they're better for boost, and the lack of oil jets isn't as big of a deal as most people make it out to be. They're there for reliability, but if you aren't going to be doing track racing where you keep a lot of heat in the engine, it's not a problem. An oil cooler would help out a lot.
As for the rods, they're the same as the DET rods. The DE block = the DET block, minus the oil jets and has higher compression NA pistons. The heads are the same too, but the cams are a little longer duration.
