Rusty cams
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Ok, so I took the motor out and started tearing it down today. The cams are toast as you can see. Pitted rust. My question is, can these be accepted after I clean the rust off as cores? I'm looking at the IPP mild cams at $510, but they charge $400 for cores and I'm wondering if these could be accepted as cores. You're looking at a clean flat section, I haven't cleaned the entire lobe yet.
audtatious
That would probably be up to the company that is asking for the core itself. If you are dealing with a parts-counter guy I doubt he would care in the least.
Return to “350z / 370z Technical”
