rusting brakes
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
kwimmer
Car: 2009 Nissan Versa
Has anyone else had a problem with the front brakes rusting? They show through the rims and look terrible. Is this also a safety concern? The brakes work fine- no problems there.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
The brake rotors are steel, so they will get a little surface rust over time. Our winters are very wet in the South, so mine get a little surface rust just sitting over night. It's very common and most cars will have it happen. It's not a safety concern. The first time you use the brakes driving, the rust will be taken off by the brake pads and everything is back to normal.
V-Man
Totally normal. It is surface rust and they will do this from just washing it sometimes. My Accord does it also, so does my brother's BMW.
aricbeemer
kwimmer wrote:Has anyone else had a problem with the front brakes rusting? They show through the rims and look terrible. Is this also a safety concern? The brakes work fine- no problems there.
I noticed not only do the front disc rust, but the rear drums are starting to show rust.
iluvmyVersa08
Car: 2008 Nissan Versa SL Sport
V-Man wrote:Totally normal. It is surface rust and they will do this from just washing it sometimes. My Accord does it also, so does my brother's BMW.
I totally agree with V-Man. Every car is going to form rust on them ... my brother's BMW does it too !
Return to “Versa Technical Discussions”
