Rusted Floorboard
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
lalsimmons
Car: 2009 Triumph Scrambler
1982 Datsun 720
Hey everyone. I recently decided to change out my vinyl floor for carpet.
I pulled the seats and started pulling the flooring and stopped. The floorboard under the driver side is rusting. Not a pretty picture, like crumbly rusting. It seems ok in the extended cab, and I haven't looked at the passenger side yet.
Should I just carpet over the vinyl and don't disturb it?
Definitely rip it out, vaccuum and clean it and have someone deal with whatever is horribly wrong?
The truck is incredibly rust free, it is so super odd that barely a spot of rust and then the floor in this spot is super rusted out. Is this common?
I drive it occasionally in good weather, it is a hobby truck I have owned since new - I baby it, so it won't get worse i don't think. I just worry ignoring the problem may be a bad idea. Or maybe they all have problems like this and it is usually contained and I should just pay for it be patched.
sm IMG_2625.JPG (30.03 KiB) Viewed 2256 times
sm IMG_2624.JPG (26.19 KiB) Viewed 2256 times
sm IMG_2623.JPG (23.9 KiB) Viewed 2256 times
sm IMG_2621.JPG (22.48 KiB) Viewed 2256 times
sm IMG_2620.JPG (33.78 KiB) Viewed 2256 times
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
lalsimmons wrote:
Wed Dec 15, 2021 6:19 pm
Rust never sleeps, except maybe in Death Valley. So your suspicions are right, ignoring it will be a bad idea. However, floorboard rust has always been common on trucks with unpadded vinyl in the cabin, simply because trapped moisture has no way out. Usually it will be limited to the sheet metal and won't affect anything structural. The most common solution is to hit it with rust neutralizer and then lay some new sheet metal under the carpet, but with a ride that's so pristine, I'd bite the bullet and do it right. Take a grinder to the whole rusted section, use body sealer to permanently lay down new metal, prime and paint, then eliminate the source with what you planned in the first place -- regular carpet, preferably padded.
lalsimmons
1982 Datsun 720
Thank you for taking the time. I will get the floor out and clean it up to see what I am dealing with. 98% chance a person who knows what they are doing will fix what I find. Do I go to an autobody, a mechanic, or is it strictly a restoration thing and I need to find a speclialist
VStar650CL
Technical Expert
Since it's under the carpet, it can definitely be a body-sealer job and not cutting and welding. So I'd think a good body shop would be the ticket.
Flynnstoned
Car: 1977 Datsun 620
1985 Nissan 720
I feel that you should pull up/remove whatever is covering the floor, soak the floor in white vinegar for a day or two or three, remove the vinegar, see what you have left to work with (probably hit it with a wire brush too). Then (if you can't weld,) you could patch it up with fiberglass. Your cab likely leaks somewhere (just found out my back window doesn't seal at all,), and instead of evaporating the moisture is just eating the metal. And that's BAD.
lalsimmons
1982 Datsun 720
I ended up having them cut out and replaced. Lucked out and find someone willing, these days rust work is harder to locate than gold.
Return to “Datsun 720”
