rusted chassiss
mattmoore68
Car: 93 240sx se
how to fix rusted chassiss of a s13 240sx?
LugNut18
Car: 1992 240sx Hatchback
any pictures, info on location, is just rust or is it rotted?
mattmoore68
Car: 93 240sx se
it is rusted under the driver and pass finder will take a pic next time i am at the shop
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
my friends *unibody frame rail type thing* (? lol) was rusted out completely! he had one of our friends moms boyfriend weld it and its solid as a rock. just use the best stuff for the job and you should be good.
mattmoore68
Car: 93 240sx se
yea that is wat is rushed at thanks
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
I believe a nico sponsor can help. http://www.courtesynissan.com
They have oem frame rails and other panels.
Nissan2367
Is the rust on the fender* or on the unibody?Nomatter where you have rust you will have to cut it out and weld in new steel. there is no easy way around it, if you dont cut it out it will come back. as a rule of thumb you cut an extra inch further then you can see.Good luck
