200sxSr20det »
https://forums.nicoclub.com/200sxsr20det-u258403.html
Wed Nov 11, 2015 12:59 am
Hi Guyz
I seem to be in quite the predicament, I have two RPS13's both with Sr20det swaps, however due to finances I can only afford to keep one, the issue I'm facing is that one has Rust in the trunk area and trunk lid, also some rust on left rear fender and roof. The another has a suspected bent frame in the rear, it seems the previous owner hit the left rear wheel on something pretty hard as the sub-frame moved to the right, I know this because I recently replace the sub-frame and the car still seemed to be driving slightly skew from the rear.
Question is: Which one should I pick to do a full Resto-Mod on and which one would cost me less to repair, Rust or Frame?
Thank you guys in advance,
your expertise are truly appreciated
