engineer20 »
https://forums.nicoclub.com/engineer20-u244945.html
Mon Jun 01, 2015 11:38 am
So I have an 03 camry and the body isn't rusted but underneath it's rusted and I live in Michigan so it snows a lot and they consequently spray a lot of salt on the roads during the winter time. My camry wasn't rustproofed, but I just got a rogue about half a year ago in November and it was driven in the winter this past winter. Should I rust proof it? The dealer said they could rust proof it, is it good or worth it? My camry, last year, didn't have anything rust off, but this spring, after checking it out, I saw the heat shield rusted off so what should I do about that and is it fine? But anyways, moving to the rogue, is rustproofing it worth it and what does it entail? Should I get it done at the dealership, or get it done in nearby Canada (sarnia/windsor, greater toronto, i heard sarnia does a good job and it's closer) They work on american cars, right? You don't need canadian registration,etc? Anyways, where should I rust proof it or should I rust proof it myself, by spraying truck bed spray underneath. Is it too late to rust proof as it's already been through a winter? The car has 5000 some miles on it now, so if I want it done, I should do it before the next winter, but where should I do it at? Thanks. Anybody have a car rustprooffed at the dealer? How was it? Speaking of the dealer, the first oil change is free and I recently did it, but it was conventional oil. THey said they used 5w30 and this isn't a rogue select and the factory fill is 0w20 and they said to use synthetic in the future, so shouldn't they have used synthetic? Was this bad to use 5w30 for the car so the dealer coudl save on costs when offering the "free" oil change? thanks, and they said the rogue needed tire rotations every 5000 miles, is that true? And dont' awd cars need similar tread or else you damage the transfer case, or is that not necessary, as I talked to the dealership person and they said that was for older AWD systems, so if I have a flat, that doesn't mean I have to replace all four tires again, or not necessarily? Thanks. And can directional tires be used on this car? And how often should I change the CVT fluid? Valvoline cvt covers ns-2 but not ns-3 as is specified, but when ns-3 aftermarket, possibly by valvoline comes out, is it ok to use it? And how do you know if you have a cvt issue as i heard many nissan cvts have issues before the warranty, so i was thinking of doing an extended powertrain warranty. how much is an extended powertrain warranty and how long does it cover until (120k?) anything after that? Thanks.
