Rust on Frame rail
Jah1mon
Car: s13 coupe
I know this is a popular topic among s13 owners. I have little experience with body work, so I need some advice.
I sanded down the undercoating and paint in the passenger side wheel well because of bubbling issues. I found rust developing in between the seams of the frame rail.
The metal is still intact, but it feels a little fatigued to the touch. I don't think I can get away with just using a rust stopper like POR-15. Will wielding and patching be in order?
I know some people have worst rust issues with there frame rails, but would this rust issue mean the car is scrap?
EpicNightMayor
Car: 1989 Mazda B2200 waiting insertion of a KA24DE
Sorry. Your car is totaled. See insurance to collect 1,100 dollars.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
cancer....its a terrible terrible thing
sldewyz
Car: 97' Danger Ranger
Koshin wrote:cancer....its a terrible terrible thing
my car can haz cancer removed
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
I came in here expecting to see the normal fist sized holes in a frame rail but that isnt nearly as bad as i thought it was going to be.
Jah1mon
Car: s13 coupe
Well, I guess I was lucky to catch it early. But the only way I can ensure that it will not return is probably replacing the rail.
EpicNightMayor
Jah1mon wrote:Well, I guess I was lucky to catch it early. But the only way I can ensure that it will not return is probably replacing the rail.
I'm giving you an reply to your above post in puzzle form. You figure it out. WORNG. Cut & Weld brother.
PoorManQ45
Cut and weld
nissangirl74
snwbrdr435 wrote:I came in here expecting to see the normal fist sized holes in a frame rail but that isnt nearly as bad as i thought it was going to be.
you can fix that, no problem. Good luck!
robinsone
Car: 1989 240sx
Not sure if this will help but I have the same problem, even worse on my 89, I found this site and almost started crying because its going to save my driver side frame rail...
http://www.xcessivemanufacturi...tep=4
Jah1mon
Car: s13 coupe
Thanks for the link.
If I'm reading correctly, is that just a cover for the frame rail?
I wonder if rust would still develop underneath the original rail if you just covered it with that one from Xcessive?
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
well you would grind off any existing rust, treat it with por-somethingoranother, then slip that patch on, weld it, then put some undercoating on it.
POR15 works well on light sheet metal rust but I can't imagine it being sufficient for a frame by itself.
Urabus GodofTraction
Car: 2002 Subaru WRX Wagon
2004 Suzuki SV650
1988 Toyota Land Cruiser
1994 Honda XR600R
240SX's are two for a dollar. Not worth the effort at all. Buy clean shell, swap in the good stuff.
Jah1mon
Car: s13 coupe
charlieo wrote:240SX's are two for a dollar. Not worth the effort at all. Buy clean shell, swap in the good stuff.
I agree, but those clean shells are becoming harder to find. It took me several months just to locate this one, which is fairly clean other than some light rust spots on the underbody.
Eventually it will be become rather difficult to locate a 240sx which would require no rust repair. Especially in the Rust belt.
PapaSmurf2k3
Site Admin
That rust is childs play... can you poke a screwdriver through it? If not, grind it down to clean metal, weld a patch over if desired, and then undercoat it.
adrianfromthecastle
Car: 1992 Nissan 240sx
robinsone wrote:Not sure if this will help but I have the same problem, even worse on my 89, I found this site and almost started crying because its going to save my driver side frame rail...
cool link man! something to consider
Jah1mon
Car: s13 coupe
PapaSmurf2k3 wrote:That rust is childs play... can you poke a screwdriver through it? If not, grind it down to clean metal, weld a patch over if desired, and then undercoat it.
I can't poke a screwdriver through it, but it's definitely soft to the touch. Cutting it out and welding a patch is required. But replacing the entire rail is also an option I see now.
tEknoS13
Car: 93' Type X
Someone had posted that recently and it is cool, but kind of steep. 200 for something you can just cut and weld yourself. I went down to the sheet metal place and bought a 4'x4' piece of 16 gauge for the frame for $15!! Then again I understand some people don't really like to touch such projects.
JDMSKYSZ
Car: 2jz Silvia S-13
Are you gonna sell iti was kinda looking for a parts car for my 240sx
Nissan409
Car: 1993 Nissan 240sx
Its really not that hard to cut and weld, if there is no gaping holes or anything serious you dont need to replace the frame rail.
Cut and weld=ez Mode.
Replacing a frame rail=somewhat of a pain in the a**, and making sure the rail is totally square, lined up, matching the other side would be difficult.
