Rust on cylinder walls....
KoupeDaVille
Car: '90 S13 Coupe, '99 Q45
Is it ok to use a high grit sand paper to remove the rust from the cylinder walls? The rust is very light and about an inch down from the deck, and the pistons move freely. I don't want to take everything apart just to hone it.Thanks, Koupe.
neverlift
use a scotch brite pad gently, just to remove the rust,not the metal.
KoupeDaVille
Thanks for the advice.
wild_maxx
Car: 90 TT pearl yellow z32
or bring the pistons up to the level of the rust then dump some brake fluid in there and let is sit for an hour.. wipe it off. I don't think its a good idea to scratch at your cyl walls....
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
no, use the green scotch pad, thats what i use on all my bearing surfaces. it takes care of light rust no problem.
Because you're probably gonna want to hone your cyls anyways. which is just a lot of organized scratches.....
green scotch pad.
KoupeDaVille
Thank for all the help. A combination of the brake fluid and scotch pad worked well.
seang
Car: Ford Fiesta ST
Firewind
Car: 240SX
I am glad this was brought up, because I am about to do the same thing.
Vegascorbin
Car: 1990 240sx dirt track race car
although the above will work, if you are going to fix it, do it right. Hone it or have it bored out if it requires it.
xckid
Car: 2004 Chevy Blazer ZR2
wouldnt brake fluid eat up the wrings
urbanskiben
Car: 1991 240sx with 93 motor bored out
xckid wrote:wouldnt brake fluid eat up the wrings
no it wouldnt eat the rings and for the green pad being that it is light and on a smooth surface it would come off easy and i wouldnt want to be putting brake fluid in or around where it could get into my engine!!
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
Vegascorbin wrote:although the above will work, if you are going to fix it, do it right. Hone it or have it bored out if it requires it.
vegascorbin is rite!..do it all the way man...if ya have the head off now anyways..you can just pop off the rod caps and pull the pistons out without removing the crank..then hone her proper and replace rings..you will save money in the end and engine life...good luck
