rust on cam lobes..
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
I just got my exhaust cam in the mail and noticed there is rust on the cam lobes..im assuming rust on these parts are bad right? haha its surface rust and will come off, but some parts are more stubborn than others.
anyone know a way i can get this off without damaging the cam, or is the cam junk? thanks..
boost_boy
Just clean it with a wire wheel and a drill and you should be just fine.
Dee
Kaforlife
Car: 1992 240sx
I used some wd-40 and some different grade steel wool came right off
Frankenfourty
Car: 1989 240sx CA18DET
The cams are fine. Get what you can off with what the above posters stated. Just don't use sandpaper. I would worry more about the bearing surfaces being clean. The rust on the lobes will be cleaned off when you run the engine. It wont ruin anything if there is a little surface rust on the lobes. No worries.
sjbsuperman1425
CA18DET
boost_boy wrote:Just clean it with a wire wheel and a drill and you should be just fine.
Dee
yea i did this and they look great. Thanks guys
themadscientist
I use metal polish by hand. That will only work on cosmetic rust. If the scale is dug in there you might be SOL.
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Pshhh, I just throw mine on the ground a few times, knocks that rust right off Lol jk. I've heard of several ways to remove rust from cams, there is a special type of polish if I remember right that is actually made by 3m or Dupont I can't remember, but you just take a rag dip it in rub the cam for awhile and it should be stupid clean, like it gets rid of anything on the camshaft down to the oil molecules left on it.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Yeah that s*** always buffs out.
sjbsuperman1425
CA18DET
hell yea i got it bolted in and everything with new cap bolts (NON Home Depot) and they both turn just fine. Thanks for the help my distant family lol
pics will be up of the new setup soon sons/daughter
Frankenfourty
Good to here you got it worked out. I know you already have yours in, but just as a reference to everyone that may need a solution to rusty cams, bearings, and other surfaces that cant really have rust removed aggressively, there is a product that works really well. I don't remember the exact name of the product but Eastwood automotive sells it. Its a gel that you coat whatever needs rust taken off, and it "eats" rust, but it does no damage to metal. So unlike acid baths that will damage metal if you leave it on too long, this stuff will not damage the metal regardless of how long you keep the gel on there. I had a crank journal that got water on it and had a coating of surface rust, and it worked great. Just trying to help some people out with similar problems.
themadscientist
You don't mean naval jelly do you?
The rust eater, not the stuff Ryan smears in his belly button when he wants to feel naughty.
Frankenfourty
themadscientist wrote:You don't mean naval jelly do you?
a
Haha, close but I don't think so. Here is the link to the stuff. Kinda pricey but its useful. I'm used to working on engines that have been sitting in a scrap yard for 30 years (Hot rodding was my passion before Nissans). So I would have loved to of known about this stuff along time ago.http://www.eastwood.com/rust-s....html
themadscientist
I'd use it but I think rust is what holds my car together.
float_6969
Don't lie Mike. I rub it on YOUR belly button when you want to feel pretty.
themadscientist
float_6969
LMAO! That's awesome.
