rust on brake rotor
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
lefty scott
Car: 2007 infiniti g35 coupe
I seem to still have some rust area on my brake rotor's even after use. Any quick any easy way to clean it?
joe603
Car: 2014 Durango R/T
It should go away after you drive it...but brake cleaner will also work. Just make sure it won't ruin the finish on your rims.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Go out and do a few 60-0 stops.
pfarmer
Car: 2008 GXS with technology package
lefty scott wrote:I seem to still have some rust area on my brake rotor's even after use. Any quick any easy way to clean it?
Take emery cloth to it. Now wipe off with a clean cloth and spray paint it satin clear.
Perry
tbradley
Car: 2005 Brilliant Silver G35 Coupe
Would this advice apply the center/hub of the rear rotor as well? My fronts are fine, just the rears are rusty in the center.
srv2nv
Could, but it will come back right away. Best thing to do would be to remove your wheel, lay a cloth around the wheel well, clean off the centre of the brake and then give it a shot of high heat black spray paint. Should stop the rust from coming back so quickly and give the brake a nicer finish. Don't worry, if you get the paint on the disc its not a problem, your brake pads will take care of that the next time you stop.
pfarmer
srv2nv wrote:Could, but it will come back right away. Best thing to do would be to remove your wheel, lay a cloth around the wheel well, clean off the centre of the brake and then give it a shot of high heat black spray paint. Should stop the rust from coming back so quickly and give the brake a nicer finish. Don't worry, if you get the paint on the disc its not a problem, your brake pads will take care of that the next time you stop.
Paint is basically paint for this purpose as long as it is good quality suitable for metal. I would tend to lean towards engine paint.
Perry
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
