Stadick_shock »
https://forums.nicoclub.com/stadick-shock-u248307.html
Sun Feb 22, 2015 2:00 pm
Okay, a little background information: It's an 85 turbo with T-tops. I bought it for $2500 a couple months ago and has been running fine. Then, about two months ago I was doing a little bit of a pull and I believe it was around 3000rpm in third gear when the car lost power and shut off.
Now here's the weird part: it only starts and idles with the fuel return line disconnected from the fpr. So far, I have replaced the fpr, fuel filter, fuel pump, spark plugs, spark plug wires, the ENTIRE distributor, and have blown air through the fuel lines. I took it to a shop to see if they could find something and they said it had fuel, spark, timing was correct, and that it's compression is almost perfect.
Now, I assume it's something electrical or a sensor because the wiring looks pretty atrocious and a lot of things are disconnected. I'm at a complete loss and I desperately need assistance, so any ideas would be a great help. Thanks guys.
