jnever1 »
https://forums.nicoclub.com/jnever1-u168056.html
Wed Jul 11, 2012 11:48 pm
It may seem silly, but I used a DC/AC convertor with a digital voltage readout to test my alternator output.
For example, when plugged into the cig lighter receptacle, I would observe 10~12V, sometimes lower, on my convertor's readout with engine running. Battery would drain, car wouldn't start/crank/etc as a result. After new cables and alternator (and a slow charge on the battery), minimum voltage I get from receptacle is 12.1V @ ~650 RPM. At 5000 RPM... lol >15V (and my convertor shuts off for safety). Surprising results since the wires and connectors are more than 17 years old.
Also, I ran heavy gauge wire from the battery terminals into the cabin for 500W convertor usage versus 100W usage from the cig receptacle. Voltage results mirrored receptacle results.
While not the preferred multi-meter method, this device offered equivalent service for my needs.
Just something to keep you thinking outside the tool-box. :-)
