All of a sudden, my 91 240sx has no power uphill and runs a bit rough at idle. I changed the spark plugs, clean the cap and rotor which I had replaced about 6,000 miles ago. all looks fine and there is no damage. I checked the timing and it's at 20 above TDC. Replaced the ignition coil, air filter, fuel filter and I'm still having the same issue. I don't get an engine light. at idle is at 700rpm, when shifting to drive, the rpm drops to about 600 and the car shakes a bit more as if it wants to stall, but it never does. I took one spark plug out at a time and the car runs rougher, so all cylinders seem to be running. I intend to do a compression test tomorrow. I'm running out of ideas on what can the problem be. Can anyone give me some ideas on what I can check next? Thanks a lot.
