Mine was running real bad and throwing Code 13 awhile back. I replaced the coolent temperature sensor (like $20 at autozone) and it ran MUCH MUCH MUCH better. If your getting that code it and it is running like dog do, fix that first!Hackysac300zx wrote:ok welp...neither the plug nor the MAF things worked still getting a 12 and 13 code...pulled the coil packs while running and found that neither 1 or 2(the front left and right) are firing...so lost...replace coil packs? could the plug clips being broke have something to do with it?
