lilleyvanilli »
https://forums.nicoclub.com/lilleyvanilli-u124786.html
Mon Jan 19, 2009 8:19 am
Thank you folks, in advance for any insight into my problem:
I am driving 35mph and it feels like transmission slipped into neutral. No big bang... no fluid anywhere... engine still running fine... and never any slow shifts, slippage, weird shifting, etc. to tell me "hmm, I think my transmission's going to go next month". ALL gears are dead and no weird sounds, shifter shifts into all gears good and tight. I added 1/2 qt of fluid, as it was down below the cold mark, once I got troubleshooting. But never any leaking fluid in the driveway.
What's been done:
Ran transmission codes and the long blink is #7 ("Torque Converter/Clutch solenoid valve [=lockup] circuit")
Q:Can anyone tell me what to check on this circuit? Is it just a dead Torque Conv.?
What's not been done:
No cleaning of connectors at TCU, or elsewhere. No checking of other things, as I don't know what to check. I hear certain things should be checked for functionality BEFORE you run transmission codes, but with all gears gone, can't I cut to the chase?
Thank you SO much for any guidance. I'm getting scared. and all this when I'm moving by the end of the month!!
