BigPar wrote:you'd think someone would have figured this out by now. Mine is doing the same as described on my RB25, and I've tried numerous things so far to fix it. I installed a nismo fpr, didn't help. I redid my timing and have it exactly on 15 degress (4 marks from the left) and still cut in and out. I'm not runnign exhaust, so I don't know if it's just not enough back pressure or what. The rpms dive bomb and try to stall at sudden stops an dlow rpms. It stalls between shifts whith the clutch held in. I'm tempted to hook up a z32 maf and safc to see if my stock maf is screwed up. Every test has been a big let down so far. The timing helped to curve it somewhat, but it's still there. and No boost leaks.
Modified by BigPar at 9:10 PM 10/17/2006
Yeah, I'm having the same problem, the only thing I can narrow it down by is the MAF, HKS does sell a unit called eids, helps with the stalls, but nevered tried it, I guess when I get my turbo upgraded the Power FC w/z32 MAF will fix it. *crossing fingers*
