What kind of aluminum radiator do you have? I have KA+Koyo and shroud fits perfect without cutting or modification. I have both upper and lower portions. It just got pushed to engine side a little bit. I also know someone with SR+Koyo radiator and his shroud fits perfect too. There's like less than an inch clearance between SR and shroud, but I have more space than that.tramp_drift240 wrote:im not using mine, but ive got an all aluminum radiator so it wouldnt fit.
Awesome write-up!!heartofaskyline wrote:step 1: whack with hammer
step 2: smash into pieces
step 3: remove pieces
done!
This picture is from one of Mishimoto raditor auction ons eBay. It looks like it's 2 1/4 inch thick. http://cgi.ebay.com/ebaymotors...ZWDVWtramp_drift240 wrote:ive got a mishimoto, its pretty thick.
the fan was hitting the shroud, and i wouldnt have had any room to put my hands down there to take off the fan. so i just left it off.
I tried these 2 steps and found out I could mess up the fins. So, I attached the shroud to the radiator and slide them from the top. It worked like a charm. Gain from removing clutch fan is not so much. You can also gain from lighted flywheel, pulley or 1 piece aluminum shaft. I think stock clutch fan works just fine.S14toRPS13 wrote:1. Put in radiator(make sure you unbolt your fan from the fan clutch before you go to step 2)2. Slip in the fan shroud
I'm holding out on you. It's Garage Defend GT cooling panel.tramp_drift240 wrote:on another note, 94_240, whats that carbon fiber, ehhhh?
Could you post a picture of your whole engine bay with that cooling panel? It looks pretty rad!94_240sx wrote:
