razzlerdazzle08 »
https://forums.nicoclub.com/razzlerdazzle08-u96929.html
Wed Apr 29, 2009 6:02 pm
I am putting a hitch and tail light converter for my 01 Pathfinder but the only problem is is running the wires. The instructions for the converter is to plug into the factory lights and run the wires through the grommets and then their is a driver side grommet to run the wires down through and then their is suppose to be a passenger side and you connect the wires to the converter box outside the vehicle. I cannot find the passenger side grommet at all. I have not got to look really hard but I did look around and could not see it at all. It is the grommets where the wires run from the inside to the outside of the truck. This is the instructions. http://www.hopkinstowingsoluti...5.pdf and the illustration is fig 3. it is not detailed enough to show where they are.
