Running way to Rich
wilcox
Car: 1984 300zx AE
Ok 1984 300zx AE and its running so rich that its burning my eyes. Senor light on dash is on but no code in ecu. Car will run but chokes itself out at idle. Throttle switch seems to be working on TB and if you unplug AAC it will idle up for abit but will start flooding itself again, any ideas would be helpful . Thanx.
wilcox
Car: 1984 300zx AE
switched ecu's and all is good
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
Check the coolant temp sensor.Even the pins on the connector may be corroded.
NTEC
Car: 85 Sentra, 85 720 kc, 89 d21, 04 Titan, 08 Titan Pro-4x
The coolant temp sensor is a very good possibility. If you wind replacing it make sure you replace the connector to it too. It is probably green with corrosion. I had 2 84's with that problem. Oh, and make sure you put some dielectric water-proofing grease on the connector when you do. I also had an airflow meter do the same thing before.
wilcox
Car: 1984 300zx AE
switched that first and did not improve but thanks for the responses still working fine.
