dbody06516 wrote:Cake Eater,
I have a walbro 225 and a nismo fpr both are on the car about 5 years.
do you think it can be a bad ecu? Thanks for your help.
Watch the NISMO FPR. They fail and when they fail, it usually starts rich and go lean in the higher rpm. Bruce, trust me on this one. Other things to be aware of is the AFM's hot wire is probably dirty or take some carburetor cleaner and attack your intake manifold; especially where the butterfly valve assembly splits up. Make sure the water temperature sensor is on point as well.
Dee
