running very rich.......HELP
fulmore240
Car: 93 240sx ka24d
car is running very rich black smoke coming out of exhaust......replaced distrubutor cap,rotor,spark plugs(old ones where only 3 months old and black like charcol on them)and replaced mass air flow sensor.....car is spuddering.....please help
Sonikfuri
Car: S13 Coupe
have you messed with the timing at all? My 240's running rich right now due to the fact that the previous owner messed with the timing. (I get to fix that tomorrow)
vancouverbc
Car: 1991 240sx
coolant temperature sensor? leaking fuel injectors? look up coolant temp sensor in tutorial link in my signature
Soravia
Car: 2003 Audi A4 1.8T
What about the intake air sensors and O2 sensors? The vaccume system leak can cause incorrect Air/Fuel mixture.I just did some vaccumes myself. My car would run so rich I had to change spark plugs within 60 miles. I'll have to wait for another 60 miles to find out if I fixed it.
On topic, IF the injectors are leaking fuel is it a good idea to replace with another used one or just replace with a new one? How about reman Beck/Arnely? Is GP Sorensen Multi-Port (Mfi) Fuel Injector better than stock?
fulmore240
Car: 93 240sx ka24d
the check engine light is not on
vancouverbc
Car: 1991 240sx
dont rely on check engine codes too much. retrieve the codes from computer. the check engine light does not always come on when you have codes. disconnect the o2 sensor to see if things improve with it disconnected. clean the o2 sensor while you are ate it.
fulmore240
Car: 93 240sx ka24d
problem fixed
vancouverbc
Car: 1991 240sx
good news. what did you do to fix?
fulmore240
Car: 93 240sx ka24d
bad ecu......but now all it does is hesitates still trin to figure out what thats from
Sonikfuri
Car: S13 Coupe
check your ground, fuel injectors (some cleaner maybe)?
fulmore240
Car: 93 240sx ka24d
im goin to check my grounds....my injectors are fine i checked them....do you know the exact number off ground wires there are?thanks man
Sonikfuri
Car: S13 Coupe
I only know of one off of the top of my head, by the valve cover, left side. If you're facing the windsheild its towards you. I gets to work on the beast today so I'll take a look to see if I can find more.
fulmore240
Car: 93 240sx ka24d
all right let me know man its drivin me crazy and im at work so i cant do anythin right now
vancouverbc
Car: 1991 240sx
just measure resistance between neg battery terminal and engine chasis. should be less than 2 ohms. see ground in tutorial link in my sig
fulmore240
Car: 93 240sx ka24d
i checked i didnt get anything.....one spot i only got .04....is there any major good spots to check
