DrifterProdigy85 wrote:Does it idle on its own at all?
the car does idle on its own fine, its only when i give it gas it dies.
srdub-t wrote:if it was running fine before the ecu i doubt your cam timing is off.. try leaving the safc in but with no feul corrections.
it never did run right before the ecu tune. it would always do the same thing but now its more extreme and undriveable.
CSUPUEBLOTIM wrote:Is it throwing any codes?
i haven't checked for any codes - i didn't think i could sense i did the sr20det swap.
judging by some of the comments i probably need to get a fuel pressure regulator and check my fuel pressure. I unplugged the safc but I have not rewired anything yet, I'm guessing I will just have to cut and splice things back to normal.
so the cam timing might still be on the table since it didn't run right before the ecu. I will try and replug the safc in first and set it with no fuel corrections before i delete it completely.
Thanks for all the suggestions!
