SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Wed Sep 10, 2003 4:33 pm
Do you have something to compensate for your BOV? If not, you will OBVIOUSLY be running rich between shifts and coming off of boost. Because you are expelling air that would normally be used in combustion; then when the unburned fuel reaches air and is hot enough, it explodes out the back of your exhuast. Do you have a cat? A cat should stop the fire, if your getting fire and your cat is not gutted then you have problems.
