DjLiquid wrote:Im very sorry to whore up this forum but my car has been parked for about a year and a half and it's finally getting safetied (a mechanic looks it over to check to see if it's road worthy before you can insure it up here in Canada) and Im trying to make sure it's going to run smoothly. I was told if im running rich that it's probably because ive got a boost leak. Well, after checking the following:
- O2 Sensor- O2 Sensor wiring- All vacuum lines and connections- Where parts meet up (and gaskets)
Everything is fine. I do have a blow off valve that is venting into the atmosphere and I know alot of you are going to say thats my problem right there. Well, without removing it, is there anything I can do to fix this problem? I was going to up my boost from 7psi to about 9psi or even 10. I was wondering if you would say 'yay' or 'nay'.... Keeping in mind, ive only driven around the block about 20 times since ive got this engine and ive cleaned the spark plugs about twice already cause they keep getting seriously coated in carbon.
Thanks for your responses!
DJ, I was hoping you guys wouldn't bring this silly subject up again, when it's posted in a stick "Do not complain about driveability issues if you're atmospherically venting your BOV. Everytime you change gears to listen to your bov, you're pissing your computer off and it's going to show you just how it can piss you back off. Just don't rev the engine and change gears just to distinctively hear your BOV. Change gears and keep going through your rpm band or just remove the BOV for now as it was intended from the factory. If you are still have problems, contact float or myself and we'll discuss this behind the scene.
Dee
