ryancoke »
https://forums.nicoclub.com/ryancoke-u47146.html
Thu Apr 12, 2007 10:15 pm
a new problem has occured, when i go into boost full throttle, it goes insanely lean, and backfires, and hesitates, the wideband is all over the place, and will go right to 20ish on the meter, but if i go say half throttle, or so it's better, some backfiring, but better, Now i have checked the injectors, the fuel filter, and TPS, and mass sensor, and it seems to be in working order. I have cranked the safc right up to the max settings, and right back down to zero, and no change on the wideband, or drivability. it just geos lean, if anyone has had this problem before, or could offer some suggestions, it would be greatly appreciated
P.s it's a KA24DET with sr370 injectors, safc, and stock everything else
Edit: i should mention that this started about 3 days ago, and progressivly got worse
Modified by ryancoke at 1:29 AM 4/13/2007
